Last night I had my first LPW ever! My wife was watching a recorded show (480 SD). I noticed it because I had just booted up my iPad and it was logging into my network. At the same time the Tablo was recording another program.
I remember the moment oh so well - it was like the first time one had sex! No longer the Roku virgin - an LPW It left both of us a bit shaken. Golly AndyâŚ
There are so many variables⌠You can get these using Netflix, Amazon Prime, anything that is a network streamer because that by definition cannot be constant. Perhaps there are extra variables with regards to Tablo that make these happen more often, Iâm just saying nothing is immune. And the âdeityâ players (Nexus and Shield) canât fix this by magic or voodoo. Because itâs not something they can control.
Normally we donât view recordings using the Roku Tablo client. My Tablo recordings are post-processed into a Plex server every night. So this âviewingâ was an anomaly for us. The wife wanted to see a show that had just been recorded without waiting for it to be transferred to our Plex server. So it was kind of a shock to our system to see this LPW (the only one that evening BTW).
Been asking myself if the Roku-Tablo interaction is a push or pull protocol. Does the Roku signal the Tablo when to stream blocks making it a âpullâ from the Roku side? Or does the Tablo âpushâ blocks to the Roku until the Roku says, âHang on a minute?â What is the âconversationâ between the two?
There is a website that has analyzed the initial (on startup) interactions between the Tablo and a client but not the overall flow from beginning to end.
@CraigRoyce - The Roku requests segments from the Tablo. Generally it builds up a buffer of segments so that things can play smoothly. However, when you see a one-time LPW like this, itâs generally a blip in the network which results in less segments being available than Roku wants. The Roku sees that itâs running out of segments and says, âHold on, give me a few seconds to catch up on my bufferâ before it continues the stream.
And I remember the exact moment it happened very clearly. I was booting up my iPad which was doing some network startup procedures. So there was network negotiation and activity at that moment. That was before the latest Roku firmware upgrade - since then I have booted up my iPad at the same time the Roku has been getting Tablo streams and all has been well without any interruptions.
So itâs a pull model, thanks. The onus is then on the client in controlling the stream. Which explains why different types of clients have differing performances in controlling the stream.
