Mutitask miniplayer for phone app
I would like to be able to have the app playing in a mini-window like YouTube when i’m using other apps.
Like this idea!
Ya, maybe others would have more reason to use the mobile app more. Even better if it could do it via Internet. Then I’d probably even use it.
I have no reason to use the mobile app except it is the only way to change your zip.
What app are you using? In the Roku app, you go to settings->guide->location and change the zip.
EDIT: I just looked at my other TV that has a Chromecast, and it is the same.
