This is a dumb newbie question, but I can’t find the answer anywhere on the site and I don’t have a Tablo yet, so I can’t just go hook it up and try it. Once I do connect Tablo to my Airport, how do I link to my tv sets (they’re both dumb as stumps, with no internet connectivity). I’m guessing I can attach a Roku box to one, and an Apple TV to the other?..
Last concern: Will wife and I be able to watch different programming at the same time?.. e.g., one set tuned to a live broadcast channel, say, and the other playing a recorded show simultaneously?
Thanks for your help. (My DirecTV agreement runs out next month, and I’m anxious to get switched over.)
Can’t speak for Airport/Apple stuff… but if you have a 2 tuner model, you could watch two different channels at the same time (note: recording is the same as watching). Of course with a 4 tuner model, you could watch/record 4 different channels.
I use Roku as the front ends for my TVs (a more lasting solution than proprietary solutions found in so called smart TVs).
Hope you get switched over soon!
@Jayce To get the Tablo to stream to your TV, you have a few options:
@jayce Yes to your first question, you can watch through Roku. With the Airport Extreme I setup a static IP and opened the ports required for external viewing.
@TabloSupport fyi, your link is for this thread
or I should say, brings me back here http://community.tablotv.com/discussion/551/www.tablotv.com/blog/tablo-tuner-math
Wow. That was fast.
Thanks all. This is exactly what I was hoping to hear. Full speed ahead.
This is the tuner math post. http://www.tablotv.com/blog/tablo-tuner-math
