I am having a problem with the same show (season/episode) being recorded multiple times. Is these a fix for this, is there an updated planned, or is this just the way it is?
Other than that I'm very happy with my Tablo!
The Tablo folks are working on “smart record” which should eliminate this problem. From all the chatter about it, I would assume it will be in the next release or very soon afterwards.
Thank you.
