Hi everyone,
After using my Tablo for a few months, I’ve moved from Washington, DC, to Brooklyn, NY.
I’m not sure how to set up my Tablo for use in Brooklyn, and how my existing recordings will be affected (if at all). What should I do?
Thanks, Tim
It should be as simple as going into settings, editing your location with your new zip code, doing a channel scan and then add to guide. You should be back in business.
Thanks, I’ll try it. I just didn’t want to screw anything up by doing something I shouldn’t be doing.
You might want to check and make sure no duplicate network feeds.
