My local stores are out of stock. Anyone else having a problem finding this?
is the Mi box good? i saw it at my local wall mart yesterday right next to the rokus
My Nexus Player is very good with the Tablo, but Mi box is a little better! Go for it.
We really like it so far!
The details on it can be found in our updated set-top-box blog: What Streaming Set-Top-Box Should I Use with Tablo? - Tablo TV
My Walmart had about 15 of them in stock when I went last night. The electronics guy said they have been selling like crazy. Well deserved - it’s a really good value. I have bought 1 as a present and will likely buy a couple more this year.
I went to Walmart to pick one up and was told they didn’t have any. I then went home and checked online and it was available for pickup that day so I bought it online and picked it up an hour or so later. Gotta love Walmart! I actually put it on a Roku tv that was struggling with Tablo and it is fantastic.
Thanks. Where are you located?
Thanks for the input. Where are you located?
I am in Mesa, AZ.
I’m in Madison, MS
Does anyone know if you can sideload apps to this box?
How to Sideload an app:
- Install ES File Explorer using the Play Store
- Download apps to a USB drive
- Use ES File Explorer to install from the USB drive
How to install Amazon Video:
- Download from APKMirror
- Sideload the app (see above)
Want a better Launcher experience?
- Install HALauncher using the Play Store
- Configure your own launcher groups
- Set it to appear in the “recommendation” section
- Bonus - you can also use this launcher to sideload apps!
Want to lose the advertised apps?
- Settings, apps, system apps, XiaomiLeanbackCustomizer
- Force close it
- Disable notifications
