Using the Android app on my Toshiba tablet, when trying to manually schedule a program, there is no “Cancel” or “Done” buttons in the scheduling window, making it impossible to schedule anything manually.
@diligent - Is this the native or downloadable web app?
Downloaded app
Version 1.1.2.0.0…is that the latest?
@diligent - That’s the native app and yes it’s the latest. Checking this out now with the team. Stay tuned!
@diligent - Can you provide the model number of your tablet and the OS version it’s running?
In the meantime, you can test out our new downloadable web app: https://play.google.com/store/apps/details?id=com.nuvyyo.TabloCordova
Toshiba AT7-C
That app on Google Play is what I am using… Version 1.1.2.0.0
@diligent - If you look at this URL: https://play.google.com/store/apps/developer?id=Nuvyyo+Inc.
If your version is 1.1.2.0.0 you’re using the native app.
Ok. When I go to the Play store, only Tablo native app comes up. But when I manually typed in the address you provided using the browser, I can now see both Tablo and Tablo Web.
I have also checked and installed updates for everything on the device too, including Android OS.
I cannot use Tablo Web app on Android installed on a Toshiba AT7-C.
Weird. We kept that pretty wide open. We’ll check out both things. Stay tuned.
Ok…thanks!
For the buttons, they do exist but because your screen is at the lower end of size and resolution, they may be appearing beyond where you can see them. We’ll do some looking and see if we can get this to resolve but it will be difficult without having a similar style tablet in house to test on.
Ok. Sounds good. Thanks for looking into it!
No problem… In the meantime, maybe you can ask Santa for a new tablet? :D
LOL! I have 3 daughters, and they’re all asking for similar stuff already. Santa’s got a BIG order already
LOL! I have 3 daughters...
Yowza! I can imagine it’s a tall order to keep them happy ;)
