I have the original two tuner device (been using Tablo since nearly the start) and about 1-2 months ago one of the channels we watch on a regular basis (WGN-TV 9.1 Chicago) started showing a weak signal and broadcast would often cut out while watching. I’m about 31 miles from the broadcast antenna and nearly all Chicago broadcast signals come from the same building…Sears (Willis) tower. I’ve checked antennaweb.org, the FCC… everyone says I should be able to get WGN-TV (though yellow like all other Chicago channels). This use to be one of the strongest channels we’d get. I tried unplugging my antenna, rescanning the channels (getting nothing), plugging the antenna back in, and rescanning and now WGN-TV is completely gone (all other channels seem to be there).
On top of that at about the same time my wife and I noticed that we would often get the message about no tuners being available when only one was in use. It use to be that I could watch one channel and then swap to another (via Roku) without waiting many seconds for the channel to tune in because the second tuner was already on that other channel. I use to be able to go back and forth relatively quickly between the two channels. But now when I switch channels I have to wait. Its taking so long it is as if I have only one tuner.
Is it possible that one of the tuners is dead? How can I find out? Is it possible that this has something to do with WGN-TV disappearing?
One more thing: After the rescan of channels I did cancel so I still have WGN-TV as one of my stations and I can tune to it. I get the channel and can see it…sort of. It gets distorted quickly and eventually I will see the weak signal message. But it does come in to a slight degree.
