Just received my Tablo 4-Tuner that I ordered from Amazon. Upon taking it out of the box I heard some rattling and couldn’t believe a new unit would have loose parts inside. Having worked electronics for 26 years in the Air Force I decided to open it up and see what was going on. I discovered what appear to be two heat/RF shields loose inside the case. I couldn’t determine where they were supposed to be located and saw no obvious mounting points. I decided to remove them and hook up the unit and see what happens. Well, everything seems to be working OK. System has been running for about 4-5 hours with some slight lags that I think are probably caused by my old router… a Belkin N600.
So my question is what should I do? Leave things as they are or attempt to return the unit? Now that things are all hooked up and apparently running OK I hesitate to take it down. I also plan on purchasing a new router in the near future…
TIA for any input in this matter…
Cheers,
Bob
