4-tuner Tablo… has been working fine, nothing in my setup has changed. Went to connect to it the other day and the app can’t find it… go downstairs to the network closet and tried power cycling it, reset … nothing works. The LED is solid blue, but I noticed on my router (Nighthawk X8) the led for the port where the Tablo plugs in never lights up… Tried switching ports and switching cables… no luck.
Doesn’t matter which device or app I use, none of them can find it on my network.
