You might want to have more than 2GB of hard drive you might be running out of hard drive space and if your not using tablo app try it works better for fire tv.
No reply from tablo? After I cleared the typo and what app I use.
I ended up rebooting the device and the delay disappeared. Could tablo not have some programing in the code to see when the device is slowing down and activate a reboot when it is required, or what is more important to know. What could a reboot have fixed? Is there a maintenance task that should be scheduled on a regular bases ? Would it be possible to send a reboot command from the app?
