On February 29th, local stations WRAL and WNCN will swap their affiliation to NBC and CBS respectively. Will this change affect any non-manual recordings? I am assuming it won’t, as long as the guide information is correct, but I wanted to check.
It should not IF the guide information is correct. But that is a BIG if, I assume the guide information will not update immediately. It may take a few days. I would contact Tablo to make sure this occurs sooner rather than later.
