so when i pick digital channel 6-1 off live tv menu, tablo shows the correct title but seems to be showing content from digital channel 6-2. i thought maybe it was signal strength (sometimes at night i lose some channels), but if i plug antennae directly into tv i can see 6-1.
any ideas? will tablo just pick the closest channel if it cant tune in the channel you want?
@jsahaj Is the content from 6.2 showing up as it should? Basically - are 6.1 and 6.2 playing the exact same stuff?
So 6-1 and 6-2 show different content? Or do you think they should be showing different content? Do you see 6-1 and 6-2 as separate rows in the live tv grid?
I asked because I also get a 6-1 and 6-2 and I soon realized that 6-2 is simply an SD version of the 6-1 HD channel, so I dropped the 6-2 from my channel guide.
my initial observation was wrong, 6-1 and 6-2 are both showing wrong channels. it appears 6-1 is incorrectly showing channel 6-3 and 6-2 is showing content from 6-4. however, i’m unable to view live tv for content from 6-1 and 6-2 (they should be distinct content - not the same as others). if i plug antennae directly into tv then i can see 6-1 and 6-2 fine. all four channels should be different content. i tried to rescan and the guides come up correctly, but when viewing 6-1 and 6-2 they dont bring up what the guide says it should be.
