Guys, I know I have seen this mentioned before but since the latest upgrade I am starting to experience live tv buffering. This was not the case prior to the update. The buferring is quick but is still annoying. I have zero buffering on WatchESPN, Amazon and Netflix so I know this is a Tablo issue. I had ZERO buferring before the upgrade so I know it is a problem with the upgrade.
I hope this is fixed soon!
I have the same experience. Very split second buffer that didn’t exist before
@wkufan92 @tacopeland Our intention is to include a ‘switch’ for fast startup in the Settings section of the next release. This way, you can toggle it on or off to see which setting works for you. Coming soon!
On my wired Roku, I have no problems with buffering, but on my wireless Roku 3, it does buffer some at the beginning (didn’t before).
I am not sure what the switch is for. Can someone with more tech skills explain why we are all experiencing buffering now and not before?
It’s all explained by Tablo in this post in the latest Firmware thread.
What i’m experiencing is different from initial video load up. I’m getting quick buffering mid stream.
@tacopeland @TabloSupport I am having the same problem with quick mid-stream buffering. Will be glad to have a working switch.
@tacopeland @JohnT We’ve heard a few reports of this since the update, and to be honest - it’s pretty odd.
Sorry to just now respond but that is the problem I am experiencing. The buffering is occuring in the middle of live tv. This was not happening at all prior to this update.
Same issue here. I see a “loading” message a 3-5 times over a couple hour period.
@snzkickin @wkufan92 Is the buffering/loading with 2.1.20 ? or 2.1.18 firmware ?
Under the web app in the browser, have you tried unchecking Fast Live TV Startup?
Unchecked Fast Live TV Startup in web app and after it started it froze. This feature has created a problem for me. Even recordings are start and stop since the update. The captioning works fine, this stream control - not so much. All updates current. The restart at last viewed may be causing some issues as well. That works most of the time, but is it worth it if the stream isn’t playing through. Using iPad and not seeing startup option there in app. Need the old firmware stream code to run instead of this irritating option.
To be correct the Fast Live TV Startup is the new firmesre features. Unchecking it goes backwards pre- .18
It was introduced bc people were having problems with the new feature hence why it comes checked by default.
Was using an iPad 2 iOS-7 = problems. IPad 4 iOS 8 - no problems. Same wifi network. Only started with last update. Since it works on a newer iPad & current iOS, it must be an iPad 2 problem. Didn’t update the iOS on the iPad 2. Synced an iPhone 4S with iOS 6 and it appears to work as expected with web app, so clearly the Tablo is doing what it should. Just an accessory problem, not Tablo.
