I have a 4 tuner Tablo and 4 TVs with Roku sticks. Have issues with playback of recordings stopping and loading often on 3 of the TV’s. Same problem occasionally with Live TV. The TV reception seems strong and Sling works without problems on all 4 TV’s. I really like the Tablo TV concept but it needs to work better. Any suggestions greatly appreciated.
Internet speeds should not have anything to do with live TV & recording playback from Tablo. It is simply going to be how good your wifi network is & your OTA signal strength. The speed recommendations given in the article you linked is for feeds being streamed over the internet.
I’m guessing a network issue because he insinuated that he is having an issue on 3 of his TV’s thus not on the 4th. Leading me to think the 3 with issues may be on the edge of his routers range.
Thanks for all the good replies. I did add the Speed Test channel to my Roku and all have the same results of about 10 Mbps. The Tablo is wired to my router. I did contact Support and they looked at the Tablo log and did a remote access. There is suspicion that I may have a HD problem and will watch Live TV with the HD disconnected to see if the problem persists. I hope this is the problem as a HD is easy to replace. I will let all of you know when the issues are resolved.
Yes a bad HD will cause issues for Tablo. I did not think this was your problem since you insinuated that it was working fine on one TV & having problems on the other 3. A HD issue would be present on all 4 TV’s.
The telephone company (Windstream) replaced their modem/router at my house Friday and the Tablo has be performing flawlessly since then. Apparently the old wireless modem was having intermittent problems causing the issues.
