Every time I’ve used pause on live TV, at some point, it craps out and re-buffers and goes to live or goes back to the live tv channel guide. Speaking of ROKU.
I have noticed the same thing on my iPad lately. Example you are watching a show that is on from 6:00 till 6:30. You pause the show at 6:15 when the guide refreshes at 7:00 for the next program. The pause fails. If remember correctly on the iPad you have to leave, go back to the guide and then you’re on live tv.
@django363 @mb190e Can you both reproduce this consistently? We haven’t seen this here. We’ll need to create a test case around this.
I will do some testing to see if I can reproduce it.
Let me put together the steps to reproduce, happened 2X I paused today already. Shouldn’t be hard.
I can reliably reproduce the issue as mentioned by @snzkickin.
After RR or FF several times live TV ALWAYS freezes (or stars a loop, or picture gets pixelated), then the Roku box (roku 2) reboots itself. This also happens with recorded TV but not nearly as often. this is happening when roku is connected via a 5ghz channel. it will also happen occasionally with the other 2 roko boxes connected via 2.4ghz channels.
Yep, I’ve seen the Tablo app crash the Roku when using FF/RW. Also again, more with Live than recordings, but it happens from both. For me it was using the “jump back 7 seconds” button on the Roku remote.
Pausing Live TV still doesn’t work. This is totally unacceptable. Pausing it works, then in a few minutes it buffers and never returns, requiring me to go back to LIVE. So if I pause, walk away or whatever, eventually I am going to miss something.
Roku3
I misstated the problem. The problem is that REWINDING Live TV 100% ultimately fails.
@django363 Can I assume that the RW feature works fine on the other devices that you’re using? I’m not dismissing this or anything; I just want to understand the whole problem. I just tried this in the office, too, and didn’t have any issues…
I can confirm also that rewinding from live TV does not work on my roku3. It will ultimately bug out and go back live. Sometimes leaving me in a loop for a bit. Because of this I am only recording shows and never watching live since its currently worthless to me like this. Also if I’m watching a recorded event and it makes it live this will happen so I never let it go past 1m.
My three week old TCL ROKU TV Live pause has failed me at least 10 times. No rhyme or reason to it. I can add that sometimes you can see the back pages but you cannot go to them.
