I noticed there are no listings for TBN and Daystar channels. Is this going to change in the future?
Try using a different zip code nearby. The guide data may populate for said channels.
Regardless open a Support Ticket so they can add the guide data for those channels to your proper zip code. This may take a few days though. So that’s why I made my first suggestion.
16-1 is Daystar in Austin, TX and there is guide data. You can try another zip code in your area, or contact @TabloSupport to have them add your station.
