Tablo is acting up. some channels dont work and some freezing. All of a sudden this error message came up.
I dont think it has to do with tablo storage because I dont record anything.
Hello @B_G33t5t45 - sorry it’s been a while since you posted this. Are you saying that the TABLO app will restart to free up more memory? It could be that your LG TV is running out of memory due to cache or saved data by other apps like Netflix or Hulu.
You could clear the cache on your LG TV using the article below or uninstall some apps that you don’t use. Both of these will clear some memory. The cache fix is temporary while removing apps is more permanent.
