I have a legacy Tablo. Recently the spining circle occurs. Then I try next morning and works fine. After several days of trouble shooting, recycling router, modem, etc. I thought maybe it was heating up after an hour. So last night I unplugged it and let it cool down and it worked. I think it has a fever. I am going to figure a way to keep it cool and see if I get more than a hour of use
Hey @falcon55 - Sorry you’re running into this.
Are you using onboard storage or a separate hard drive with your legacy Tablo?
Buffering can be a symptom of failing storage. If you have a separate hard drive, try disconnecting it temporarily and playing live TV.
If no buffering occurs after an hour, your drive might need to be replaced.
Where do I get the drive replaced
This should help: https://support.tablotv.com/hc/en-us/articles/360021281612-How-to-Install-a-SATA-Drive-in-a-Legacy-Tablo-QUAD
Thank you
