Legacy Quad 1TB won't record or playback with new app
Last week my Tablo stopped recording and playing back existing recordings. Uninstalled the app and reinstalled the new 4th Generation (dark blue) app. Even though there were about 450 GB of programs on the internal drive (not using a USB drive), the “Settings” now shows “No Storage Device Connected.” I’ve tried power cycling and hitting the reset button several times to no avail. It will neither record new programs or play old ones - “Storage full” or something like that appears as an error message.
Anyone faced similar problems? Were there any solutions, or is my internal hard drive now just a (relatively light) boat anchor?
Hi @MikeTeavee,
Try removing your SATA drive and setting it back in. If that fails, contact Tablo Support? They may be able to help.
I reseated the internal drive, and that restored the storage option, at least in the menu. However, old recordings will not play, new recordings will not record for more than a few seconds, and the live TV, when it works, buffers constantly to the point of unwatchability.
As a test, run your Legacy Tablo without a hard drive (power off, disconnect drive, power up). See if Live TV works any better, if it does it could indicate a hard drive issue.
Yes, I just now did that while on the phone with Tablo support. TV works fine with the internal drive out. So I guess my hard drive is the problem. Now I just have to accept the fact that the 450 GB or recorded programs I was looking forward to watching (mostly documentaries) are simply irretrievably gone. Sigh.
Because this is a Legacy device, I believe there may be a way to use Linux to make a bitwise copy of the hard drive. I don’t know if anyone’s ever been successful, but it’d be worth a try if you have an means. Maybe ask Support if there’s a way to replace it while maintaining the content.
Long shot, but could be the case that the Tablo SATA controller is flaking out. If you have a SATA/USB adapter you could test the drive via Tablo’s USB connection.
Also, if you have content you want to save, consider a tool like TabloTools.
