Guide data for channel 3.1 (NBC - KVBC) in Las Vegas is showing data from an Arizona channel with completely inaccurate data. It has been this way for several months. Finally reporting…
Try using zip code 88901. tvlistings.zap2it.com shows NBC programming for channel 3.1 at that zip code. They use the same guide source that Tablo uses. Sometimes changing zip codes solves Tablo guide problems.
Great advice. That worked. Thanks.
