The picture is portrait only on my Galaxy S4 which is using Android 4.4.2, but on my HTC EVO 4G LTE which is using Android 4.1.1 the picture orientation changes as the phone orientation changes, which is what I expected. Any suggestions?
Works ok on my S4. You don’t have auto rotate disabled, do you?
I feel stupid...just looked at the phone options and the Auto rotate button was NOT checked on the S4. Checked it and it rotates correctly.
Discovered prior to coming back here and was going to post that. I don't know how that got unchecked. Maybe Netflix just rotates with the phone movement without checking if it is checked.
Glad you got it sorted out!
