I’m building a home, and setting up my audio and video from scratch (or, almost from scratch). The one piece that I’m keeping is my Kodi device (formerly XBMC) running on a Raspberry Pi (OSMC distro). The only reason I haven’t ordered a 4-tuner Tablo with a lifetime subscription is because I haven’t found a way to integrate the Tablo with the OSMC front-end. I need OSMC instead of a Roku for the integration into my whole-home audio system.
Install the PleXBMC plugin in Kodi and then install the unofficial Plex Tablo channel on your server. This is currently the only way to access a Tablo from a Kodi device. I’ve got this setup on a CuBox i4 w/ Xbian and it works fine. There’s a couple of nuances to this setup, but for the most part it works pretty well.
This assumes you of course are running a PLEX server somewhere (I happen to) but I would also appreciate a KODI plugin for low end players like KODI on a RaspberryPi
Oh, I completely agree with you. I’d like a native Kodi plugin over having to launch it this way. Takes the stress off of my Plex box and puts it back onto the local hardware.
That’s okay. HDHomeRun has a Kodi app. I’ll probably just buy one of those, then. No PVR, but I can put together a TVHeadEnd on an OpenElec RaspBerryPi 2 relatively easily.
I’m surprised the Pi is working well. I decided to use Android media players that have a hardware codec chip. Solves problems playing HD content (stream or file) as well as DRM material.
I was actually surprised to discover you can run Plex Media SERVER on the Raspberry Pi 2 … I was skeptical so I tried it myself with some test video files that make the fans kick on with my PC/Linux based PMS and it indeed worked great for 1080p streaming… color me shocked.
They are what I use to build working prototypes of custom embedded equipment (if it does not need a tonne of storage).
I work in Python and am tickled pink to see how tight the integration is under Debian. It blows me away they got the general purpose I/O drivers - and bus drivers - built into the Linux kernel.
So as soon as I hook up a sensor, like temperature, within milliseconds a device interface file - with the current temperature in it - appears on the “disk”! Instead of writing device drivers, I just read the file. Brilliant!
Raspi works so well I think at least one prototype is going to become the heart of a client’s first production model run… Very cool.
I was really impressed the Rpi2 could handle the task of on demand video transcoding… but I also like them and I think at last count I got like 6 of them … lol…
While I only had a “test” setup I am seriously considering moving my primary plex server over to be Rpi2 based since its low power when idle which is a nice plus.
