Any other Tablo users in Seattle? I’ve lost KING-TV in my channel list as of yesterday. When I do a channel scan it hops right over channel 48.
We haven’t heard of any outages for guide data - though if you’re not able to scan it in at all it’s likely a reception issue. Not insinuating that your signal is bad; the broadcaster may simply be having OTA issues at the moment.
I lost the CBS affiliate in Cincinnati for almost a week due to an outage on their end… Check the stations website, oyu may find that their OTA capability is broken.
I discovered something interesting this evening. It seems as if either (a) the gain on my massive Winegard Yagi is too high for the Tablo tuner or (b) I was suffering from severe multipath interference or © both. After an hour of futzing around with the Winegard in the attic and getting progressively more annoyed, I stuck my cheap and cheerful RCA omnidirectional in the attic. And there came KING-TV with 5 green dots. I’d also been having issues with KOMO-TV (which is 15 miles away and puts out 1000 kW of broadcast power), and so far it’s all looking good.
@Pundit - Glad you got it sorted out.
