I use Tablo Android app on my fairly recent Sony TV. When I finish watching a TV program, I use my Sony remote to turn the TV off.
If shortly after, I turn my TV on, I sometimes directly see the Tablo screen I was watching. But fairly often I get the message Unable to find MyTablo Try again or cancel.
I usually hit the Back button and select the Tablo app from the app menu…
Is there a way I can force Tablo to remain the active app? I do not see any time-out to adjust. Equipment is ethernet connected with DHCP active
This is probably more of a Sony and networking issue than a Tablo app issue. Based on the “Unable to find MyTablo” message my guess is that the Sony TV has not been able to reestablish a network connection before the Tablo app has been restarted.
You are probably seeing the result of a race between getting the network established and the app restarted.
I just realized that if I hit the remote Apps button (instead of Back or Home), the first app of the apps menu is activated. As it is usually Tablo, that makes things faster! Problem solved!
