anyone experiencing digital/jerky playback? I have full signal for local channels. Anyone had this/fixed it?
@Sparkhawk I have this on one of the channels that show older shows like Perry Mason which I probably won’t use anyway. Nonetheless, it is very perplexing, because it has as strong if not stronger signal than some channels that look just fine.
I have been fighting this problem since first receiving Tablo. I started a Google+ community to share images and experiences. My suspicions are this based upon experimentation. 1080 resolution channels have a lot more problems than 720p channels. Look at your signals in Settings and try viewing strong signal in the lower res or record it. Then do the same with a higher res channel.
@Sparkhawk - Sorry to hear you’re experiencing issues. Poor video could be a few things. Check out this troubleshooting info to see if one sounds like what you’re getting: http://support.tablotv.com/hc/en-us/articles/201916747-Video-Quality-Is-Poor
Issues seem to have gone away? I did nothing.
@dtwick - I looked at your “trials” link and was surprised by how bad your playback is at times. During the initial Tablo setup I chose a recording resolution of 1080, and so far playback through my Roku has not exhibited any of the problems you have run into. I attached a hard drive during the setup, so have never tried to run the Tablo without one. I am using a component connection from Roku to TV.
I actually ran for 2 days without a hard drive, and mine worked fine.
