After I installed the Tablo antenna on an upstairs window it worked fine until it got windy. During heavy winds the TV would breakup or freeze up due to nearby trees. I had no choice but to re-install the antenna in the attic.
During the process of installing the antenna in the attic and running the cable to the Tablo below my body weight caved in a ceiling drywall. I didn’t fall through but did a bit of damage. Fortunately the ceiling affected was inside a closet. The repairs were straightforward, frame the inside closet ceiling with 2x2s and screw the new drywall to the 2x2s.
It’s not easy being me.
It’s been months since I moved the antenna to the attic, above the tree line. Now Tablo works reliably even during strong winds,
