Issues With Samsung App Since Firmware Upgrade
I have Samsung S90F OLED. Since the last upgrade I’m having pixelation problems. Occasionally, the picture suddenly stops and I’m presented back to the Tablo guide. As a comparison, I change my input option on the same TV to use a ROKU stick. Using ROKU connected to the same TV I am NOT experiencing the same issues. To summarize, using the Tablo App for Samsung presents display issues but when I use the ROKU to access Tablo on the same TV it works much better.
I forgot to mention that I am running 4th Generation!
Hi @mehamburg ,
Try clearing your Samsung’s app cache. That may help.
So I just discovered that an electrical appliance that we began to use in our home around the same time along with the fact that the coax cable I’m using is an older RG59 cable appears to be the source of my issue. When I turn off the electrical appliance the pixelation issue disappears. I’m going to replace my older RG59 cable with a new RG6 shielded cable to better deal with situations like this. I’m optimistic this will fix my issue. Sorry for quickly blaming the upgrade - user should know better.
Kudos for find the anomalous source of the interference. Things like that can be incredibly hard to trace down.
Can I ask what the appliance was? Is it something that cycles itself on and off automatically?
It’s ok. Sometimes, the source of electomagnetical interference (EMI) and radio frequency interference (RFI) is not easy to detect. Shrewd detective work on your part.
Personally, I think RG59 cable should have been phased out a couple of decades ago. Coax cables should be RG6 Dual Shield at a minimum.
We’re just glad to hear that you’ve found the source of the problem.
We are curious though, which appliance was causing the issue?
