Had TabloTV gen 2 about a month. Playing recordings generally works, however it seems there is a problem watching a program while it is still recording. Video freezes, “loses its place” and suddenly skips to the end. It does not seem to happen when watching AFTER recording is complete, but I don’t have enough data to know for sure. Happens with Roku TV and AppleTV so I think its specific to playback on TabloTV.
Yes, this is a known shortcoming of the Apple TV app, that from what I’ve read is not likely to be fixed.
It should not be a problem with Roku, however, so you should concentrate on troubleshooting that. Contact @TabloTV for help if necessary.
There is a separate, outstanding problem with Roku that can affect either playback or sound. See here: https://community.tablotv.com/t/update-on-4th-generation-tablo-compatibility-with-roku-os-14
To avoid confusion here, be aware it’s called “4th gen” ![]()
FYI…we watched a show last night on our Gen4 device via Roku while it was recording. We had to go to the Library and select All Shows, then click on the show we wanted to watch. It wouldn’t let us from the list of Latest recordings. I may have some of my tab names wrong because I’m not in front of the device at the moment.
I had this issue with FireStick. My Gen 2 died (I think–perhaps just the HD) and now I have a Gen 4. Haven’t really seen this issue yet.
Yes, cant use device when all turners are recording
You can watch a channel that is being recorded. But if you’re recording on all tuners and wanted to watch something else you cannot. Unless it’s a FAST channel as those don’t use any OTA tuners.
The platforms on which the app is running can have issues when communicating with the app. As mentioned Roku and Apple both have shortcomings which are presented by the Tablo apps therefore getting the blame.
