Does Tablo have an API?
How would one integrate Tablo into various home-automation apps, e.g. SimpleControl, etc.?
(Not necessarily SimpleControl, because they’ve gotten too greedy, and it’s got to go! They are pushing their own IR control dongle now, and no longer support Global Cache’ for new installations. Sure, I am grandfathered, but I know damn well they will eventually pull the rug out…)
Edit: I see now from some searches that there is an API and a developer program. What I need I think is MUCH simpler than what I’ve seen, though. I don’t need to extract a stream, etc. What would be great would be a simple REST API for the AppleTV app. e.g. so that I can command it to play a certain channel or maybe play a recording.
