Often watching via “Live TV” or recording I’ll lose the signal yet I can watch using the built in TV tuner with no issue. Great quality, no pixilating.
Is there a specific Tablo model that has a more reliable tuner, or plans to introduce one? Someone explained that the signal can be weak due to it being split going into the Tablo, so I assume the 2 channel would be better than the 4. Is there a 1 channel in the works? I have an old 2 channel, or newer ones improved?
Bit of an issue as live in Toronto and love PBS out of Buffalo. Normally PBS is great but missed Masterpiece last night. " Recording failed due to weak signal."
For the original 2 and 4 tuner Tablos, the same splitter was used in both the 2 and 4 tuner models, so in that case 2 tuners isn’t necessarily better than 4 tuners.
There is anecdotal evidence the new 2 and 4 tuner models may have slightly better tuners.
Since the Tablo models have both a splitter and amplifier, which tries to compensate for the split, it’s not an apples to apples comparison to a TV where you are running the antenna directly into the TV, which only has 1 tuner.
Completely different topic … if I was to purchase a new one, I would be tempted to try the direct connected one. My Original is from 2014?, so I’ve had good use out of it.
Can I still use my PC to schedule recordings? Or does all that need to be done via the Tablo?
