I have Tp Link router,is it better to use wifi direct from modem (Frontier) or through TP Link Router
You can only connect your router directly to the modem, unless the modem is a combo unit. And if it’s a combo unit you shouldn’t be using a router as well unless you know what you’re doing.
It’s alway best to connect the Tablo unit to your router via ethernet (wired) if possible.
