iOS app crashing
FYI
For me, starting with the app closed, after the splashscreen, Homescreen opens.
If I select Library or Live, they open for a few seconds, then crash and return to homescreen.
Second attempt to open library or live has been working, no crash.
I have been experiencing this as well.
After this most recent iOS update, the app was working super fast, relatively, now it also can take a while, 20+ seconds, to start up after the splashscreen is done.
Before the update, scheduling and deleting were balky. Have not tried since the update.
I am not complaining, just observing. These are the facts of digital life IMO and I am not ready to change over to another system that will just have issues of its own. :slightly_smiling_face:
Hi @tabjoe,
We had a look on our end and noticed a similar sounding issue, where the app will ā€˜reload’ itself after initial launch after about 10 seconds, but it remains in the app itself. Are you seeing the app crash where it’s then no longer open and you see your iPhone’s home screen? Or did you mean the Home screen of the Tablo app?
ā€œHomeā€ screen of tablo app,
the screen that comes up immediately after splashscreen
BTW the problem is on both my iphone, and ipad
@TabloForumAdmin Yes, Tablo Home Screen.
Today, Tablo app says it can’t find either of my two Tablos.
But I have no problem finding them using the Roku app.
Check that you’re connected to your home network, and that your phone can see your Tablo(s). I had a similar problem yesterday and it turned out my network cable became disconnected from the wall while I was cleaning. All my wired devices (to the switch upstairs) were not working because of it. Of course, it’s always the last thing you check. :zany_face:
Good idea, but I checked that first, phone is connected and the other apps requiring wifi work OK.
Have you already rebooted the router and other components? :face_with_peeking_eye: I’m sure this isn’t you’re first rodeo.
Thank you.
No, I decided to see if it would fix itself,and now an hour later I have tried again and now my iphone can connect to both tablos.
Just a guess, sometimes I do not connect to tablo on the phone for weeks, and maybe when I then try to connect again is when the fault occurs.
My iphone has done all this before, sometimes a router reboot and tablo reboot and power cycle help, sometimes not. I am to the point where I ask myself do I really need to use the phone for tablo at this time, answer is no, and I just come back later.
I connect using the ipad most every day, and sometimes the tablo app is a little slow to start up, but it always connects and works. Same iOS version on phone and ipad.
Both ipad and roku connected to tablo during the above incident where my phone tablo app could not connect, BTW.
Same thing here last week. I didn’t change anything big, just did a quick magfone ios system repair thing on my iPhone and it’s been fine since. Guess iOS had a small hiccup. just can’t afford a new one.
