I got this one:
I bought it on www.amazon.com, but they don’t seem to have it anymore.
I got this one:
That signal strength on the Tablo is different I think. That’s the video capabilities of the channel it’s self that you see on RabbitEars.Info. For example, On RabbitEars.Info if you click on NBC, you will see a column for Video, I’m assuming that’s what is being shown in Tablo.
I believe it’s an actual measurement. The signal strength does show a decrease when I do a channel scan after turning the antenna away from the antenna farm.
Thanks for the info. I like this Winegard meter but I don’t want to invest more than I need to so I think the cheaper Mediasonic is in my future.
However, if I had to start over, I’d probably get this combo instead. Placing it here for others that may need a preamplifier and would get a signal meter along with it (or vice versa).
Winegard Boost XT Pro Preamplifier + Signal Meter Review
i use a signal filter on my tablo
