I fell asleep watching live TV on my Tablo. It was repeating a minutes worth of the show. I tried exiting Tablo and start watching it again. That didn’t work. I pressed the blue button, and unplugged Tablo. Waited a minute and plugged back in. Then it went back to working.
@TabloTV I have NOT had any problems, but last night as you might know, the time went back an hour. Could be watching when the time changed have caused the problem? Hopefully, it goes back to the excellent performance it has been since 2.2.6.
I JUST checked the time on Tablo and it is correct. I have my router set up to get the time from a time server.
Just thought of something not related to this - if the router is set to use Zulu time, is Tablo smart enough to know to convert it to correct time zone based on zip code? Could that be the problem for those that have recordings missing? What if where you live observes daylight savings time, but they don’t change the time on their router?
