What is the best indoor antenna to us with tablo. Thanks
I recommend you figure out tower locations (distance/direction), frequency, etc first. You can do this by going to www.tvfool.com and/or www.antennaweb.org. Both of these sites will give you important details that you can share here and then get better antenna recommendations regardless of what you are hooking up to.
Oh ok sounds good, thanks!
