OK, all that I have connected to my Tablo is the digital antenna while my Roku stick is connected directly into my TV. The challenge I have is how to record a streaming program that’s on the Roku (NBC Sports Gold) onto the Tablo? Can I instead plug the Roku into the Tablo? So far I can’t get NBC Sports Gold to show up in the Tablo directory…Please HELP!
You can’t record Roku channels on the Tablo. Only OTA (over the air) broadcasts. You play back those recordings to your TV using the Tablo app on the Roku.
Looks like a gizmo like this would work, but I imagine it is expensive.
Basically one would need a device that would accept analog or digital video signals and output a digital tv channel that could be merged with the antenna OTA signals (or use an A/B switch) and fed to the Tablo.
Maybe the Chinese will come up with a cheaper version?
I figured something like that had to exist. Never knew how to get one. I wonder how it handles HDCP content?
Black Magic Intensity Pro 4K card for PC, or Intensity Pro USB3 shuttle for regular HD are two ways to capture HD or 4K source with audio using a PC.
Regarding HDCP, there are several “splitter” cables that do not pass through the HDCP component to the output signal.
http://www.mcmelectronics.com/product/STELLAR-LABS-33-11980-/33-11980
They only claim HDMI 1.3 HDCP 1.2, and it allegedly is only good for max 720p/30Hz with about 100ms of delay…
You know you have reached the end of the cordcutter universe when someone wants to take a pay package OTT service with DRM and mesh it into a OTA product.
Maybe it’s explained in the NBC Sports Gold terms of service:
You may use your account to access a maximum of one (1) stream of
Content at any time across all of your Devices. Simultaneous access to
multiple streams of Content by a single account holder is strictly
prohibited. You may not either directly or through the use of any
personal computer, browser, laptop, tablet, mobile phone or other device
(each a “Device”) or other means remove, alter, bypass, avoid,
interfere with, or circumvent (i) any copyright, trademark, or other
proprietary notices marked on our Services or Content, (ii) any digital
rights management mechanism or other content protection or access
control measure associated with our Services or Content, or (iii) any
advertisement on our Services and/or within Content. You may not either
directly or through the use of any Device or other means copy, download,
stream, reproduce, duplicate, archive, distribute, upload, publish,
modify, translate, broadcast, perform, display, sell, transmit or
retransmit our Services or Content unless expressly permitted by NBC
Sports Gold in advance in writing. You may not incorporate Content into,
or stream or retransmit the Content via, any hardware or software
application or make our Services or any Content available via frames or
in-line links, and you may not otherwise surround or obfuscate the
Content or Services with any third party content, materials or branding.
You may not use any software robot, spider, crawler, or other data
gathering or extraction tool, whether automated or manual, to access,
acquire, copy, monitor, scrape or aggregate Content or any portion of
our Services. (See Section 21 below for terms applicable to use of links
to our Services.) You may not knowingly or intentionally take any
action that may impose an unreasonable burden or load on our Services or
its servers and infrastructures. You may not build a business on, in
whole or in part, resell, redistribute or recirculate or make any other
commercial use of, or create derivative works or materials utilizing,
any portion of our Services or Content, whether or not for profit.
