This is obviously a Roku question. Sometime when I leave the Roku on my selected channel, and turn the TV off, I can return hours later, turn on the TV, and the selected channel is still there. Other times, when I turn the TV back on, the Roku has gone into its screen saver mode or back to the home page, requiring multiple button pushes to get back to Tablo > live TV > selected channel.
If the Roku is playing Live TV from the Tablo it should not go back to the home screen nor initiate the screensaver.
If left on the Tablo UI but no active playing of anything it will again initiate the screensaver after 10 minutes. But it will not go back to the Home screen. You need to press the home button for that to happen.
What Roku do you have?
Roku 3, less than 4 months old.
Yep but screensaver mode is fine, press any button on the remote and Roku will go back to where it was in the Tablo channel.
If you keep the Live TV playing 24/7 in the Tablo you might burn out the tuner.
Seriously? If I keep an antenna plugged into a TV and run the TV 24/7 there shouldn’t be a problem. Why would the Tablo’s tuners be more fragile? I could see a possible longevity issue with the external HDD and it constantly running, but why would 24/7 Live TV burn out the Tablo’s tuner?
@Whatzit I think what @theuser86 was suggesting is that any kind of ‘constant use’ for any piece of technology isn’t necessarily ‘good’ for its longevity.
You think if you left your HDTV on 24/7 everyday your TV would last years?
I’m just suggesting there is no point using the tuners when not actually watching TV or recording.
we haven't heard of a tuner burning out due to extended use.
Thanks for the clarification. I’m the PBX Tech on a little University campus, so I live in a world of “Five Nines”, and previously fixed consumer electronics at a component level, so I just thought the statement interesting.
OK, getting back to the original topic, it seems that after the most recent firmware update, the Tablo will drop back to the channel list at the top and bottom of the hour while watching live TV periodically. I have determined that each time my Roku has dropped back to its screen saver overnight, after leaving Roku/Tablo on a live channel, the Tablo has dropped back to the channel list from live TV. Which apparently causes the Roku to eventually drop into its screen saver mode, so it would appear that the Roku is not at fault.
@lewit57 Tablo will stay on the live channel for 10 hours as I understand. So was it longer than that?
@Jestep Good question. @lewit57 Any idea how long it’s been left idle when it returns to the main menu?
Interesting! This phenomena is happening either overnight or when I come home after work. I will keep a log of ‘shutdown’ versus ‘startup’ times and report back.
Well, it would appear that the Tablo does have a 10 hour shutdown timer. I shut down my downstairs TV at 7 PM last night, and this morning the Roku was in screen saver mode, and the Tablo was displaying the channel lineup for 5 AM, which is 10 hours after 7 PM.
@lewt57
