For knowledge/testing and troubleshooting, is there a way to find the actual uptime (a la *nix ‘uptime’ command)?
Either through the GUI, or via CLI?
TIA
TIA
some have put their units in “heartbeat mode” and waited to see when the LED goes solid again.
Hello @MotobikeMan - thanks for the reply. Here is what I am thinking:
I am looking for a way to show the current length of time the unit has been “up” - whether to show stability, or during troubleshooting with precise times that show it has been running.
Here is an example from *OSX command line:
16:28:10 up 102 days, 19:10, load average: 1.03, 1.14, 1.16
Here is an example from DD-WRT (router)
Time: 03:30:01 up 60 days, 3:30, load average: 0.00, 0.00, 0.00
Here is an example from ASUSWRT (router)
102 days 19 hours 12 minute(s) 14 seconds
The above commands take away the end user needing to watch/monitor manually.
Use some software like PRTG that can monitor devices on your network via ping or http and then it will log it for you with a graph and everything. PRTG is free for 100 sensors.
