I know how to record future shows from the guide but, I can’t for the life of me figure out how to record a show in progress with the Apple TV Remote. I had to go to the web app and rec it from there. Thanks in advance for any help?
I don’t think you can do this on atv.
It’s one of those things you can’t do.
You can record a show that is already in progress you go to the guide and from there it gives you the option to record but if you missed 15 minuets of the show it will not record that part just from when you tell it to record.
