How many over the antennas needed?
I’ve been trying to Google for an answer to my question, can’t find anything close enough. Haven’t purchased one just yet, until i can get my question answered. Thanks.
If i have 1 Roku tv already set up with an OTA, does the 2nd Roku need an OTA, (i can’t see the ports to plug in 2nd atenna, it’s mounted on wall)? Or does Tablo solve that issue?
You only need one good antenna to hook up to your 4th gen white Tablo. There is an antenna coax male plug on the back of it. Then, it transmits both recordings and over-the-air via an internet connection.
Thank you very much.
I have one good quality antenna that is connected only to the Tablo. I have four different TVs around the house each with a Roku. My Tablo and one of the Roku is connected via Ethernet, all the others are connected via Wifi. I can watch TV with the Tablo app on Roku concurrently on all four TVs.
