Is there a way to get my Tablo all the way back to Factory settings, so that it no longer has the ID (Tablo Name) that I originally chose? I’m just not sure if a hard-reset removes the name I gave it.
You can rename the Tablo from the Settings screen.
A factory reset changed my Tablo’s name back to the original.
However, if that’s the only thing you want to change, you can do it via my.tablotv.com
In the Settings category, General section, Tablo Name:
Thanks all. This is in preparation for selling it so I wanted to remove any semblance of my setup before I put it up for sale.
