how do I find my tablo model number
Is it the white puck? It’s a fourth Gen. If it a two tuner or four?
If this is the case, then your Tablo would be a #-tuner 4th Gen (ex: 4-tunetr 4th Gen).
Also:
Yes, mine is the white puck. Not sure about 2 tuner or 4 tuner. Thought it only had one. How do I confirm the number of tuners?
Not sure if I got all your reply, You were saying something about serial numbers???
If you still have the box, it should say somewhere on the front at the top, in small letters… maybe under a purple background?
Did you click on the link? It’s the Tablo Support Article that answers your original question:
