So I just got my tablo. Excited. But I’m frustrated at this point. I’m trying to setup over wifi and every time I try to put my password in to reconnect to my home, it won’t join. Just stays grey. What am I doing wrong?
Tablo doesn’t support the old type of security protocol so if you’re using that on your router you have to change it. I think it’s called wep or wamp, not really sure of the name.
