For starts I don’t know what I’m doing but have found the way to my NVG589s NAT/Gaming tab and think I need to be adding a Custom Service.
my Tablo app lists:
Hypothetical numbers
Public Port Private Port
25001 8889
25001 90
In the Router, my Custom service choices are:
Global Port Range ??? ???
Base host Port ???
So what goes where?
Also, what’s the Protocol TCP/UDP or TCP or UDP
Appreciate the help.
Also I’m assuming I don’t do anything in the Hosted Applications window.
Still need help but am making a little progress. Got one port working but don’t know how to get the other port working.
25001 8889 NOT WORGING
25001 90 WORKING (it’s green and had a check by it)
Got it figured out.
Set up 2 ports
25001 8889
25001 90
Forgot about the range setting and set one to
25000 range 25000 to 8889
25001 range 25001 to 90
Good luck to others.
Yes from your initial post you had the same public port forwarded to two different private ports, unless that was just a typo.
