Searched the discussion board, but could not find anything on this topic.
Plugged in HDD and the light continues to flash, as though it is stuck in a read/write loop. The HDD is not recording anything and no one is watching any content. Is it normal for the HDD to run continuously as though it’s performing read/write functions?
Has your HDD been formatted yet by the Tablo?
If not or you’re not sure, log in and look at the settings menu from a web browser.
If so, what make, model, and size is it?
yes, formatted by Tablo during the setup process. It’s a 2TB WD Elements Drive
Thanks
@dknight Does it ‘sound’ like it’s working? Different drives have different status lights. Some will flash continuously when their ‘idle’ and others will just remain solid/off.
its runs very quietly, sounds like it’s performing read/write activity, but a little hard to tell
I have a 1TB WD Elements drive and it flashes continuously. It’s cool to the touch and silent as a tomb. I assumed this was normal behavior for this drive.
thanks for the input, probably same deal with mine
