I have to do a channel re-scan every morning as no channels show on the live feed. after doing a re-scan poof all channels everything is back as normal. ?? not sure why.
I wonder if the rescan forces the guide to download. Tomorrow AM can you force the guide to download in the settings and see if that works?
I will give it a try, Thanks
Try selecting rescan but before saving that. Deselect then reselect some channels then save. Supposidly, that will clear your cache.
So this issue is resolved, tried both of the suggestions above. Not sure which one worked, but the problem is no longer an issue.
