My hard drive, a 2TB Western Digital (something?) in a generic USB enclosure would not format after repeated attempts. Tablo would show that it was formatting the drive, the drive light would show activity for a while but ultimately I’d end up back with Tablo telling me that the drive needed formatting.
That’s good info @howdysteve - We haven’t had a lot of luck with drives in generic USB enclosures. Keep us posted on how your reformatted drive works.
Things aren’t working so well. All I get are recordings with the red ! next to them. If I restart everything, then I get a good recording or two and then back to red !. It would be nice if I could see what happened. Is there any way to access an error log?
@howdysteve - Yes, there is. Please send a note to the support team (support@tablotv.com) and they’ll look into this for you. We’ll get it solved so you can start getting some successful recordings.
I would guess that it’s still your hard drive though. Even though it may have formatted, it may be frequently disconnecting from Tablo and a disconnect during recording would cause a failure.
What Hard drives work with this product. I could not find a 2 TB drive so I bought a 3TB drive. Well that didn’t work. Then I pulled out some old 500MB drives. Well that didn’t work!
There is an extensive thread in stickied on this forum about what hard drives work and which ones don’t. The requirements also clearly state it needs to be 2 TB or smaller.
The Tablo folks are trying to make more drives compatible (it must be a very difficult problem since they have spent about a year on it), but the user community has been really good pointing out the good ones.
Which 500 GB drive were you trying? Please provide exact make and model.
I’ve tried internal 200 GB and 320 GB drives with a USB enclosure and they work well.
There is an extensive thread in stickied on this forum about what hard drives work and which ones don't. The requirements also clearly state it needs to be 2 TB or smaller.The Tablo folks are trying to make more drives compatible (it must be a very difficult problem since they have spent about a year on it), but the user community has been really good pointing out the good ones.
Not only that thread, but it’s talked about in several other threads here, and it’s in the FAQ that it’s limited to 2T and then not all 2T.
@GZraick - Sorry to hear you ran into an issue with your hard drives. As the other users have pointed out, Tablo is currently unable to work with hard drives larger than 2TB and other drives due to sector size issues. This is an issue that we’ve been working on (as Snowcat pointed out) and there is light at the end of the tunnel. Once we have completed work on our new kernel you’ll be able to use that lovely 3TB drive.
