If you don’t force close the Apple TV app, when you go back in a day later, the guide is sitll not correct. When that happens, I force close the app and then start it again. Without force closing, you must scroll for a day or two to the left to get to the correct day/time.
I have the exact same problem. Mine does not do that all the time though.
This is still an issue. I have to force close the app and restart to get to the correct date/time in the guide. Only on Apple TV though.
Hi Ala,
Sorry, you’re running into that.
Do you have the latest version of our Apple TV app? It should be version 1.8.0.
It’s 1.8.0 (36)
If you watch live TV, exit to the Apple TV homescreen, and go back into Tablo the next day, the guide will scroll horizontally back and forth, and eventually settle on something that is not even the same day.
Would you be willing to share a video of this with our support team (https://support.tablotv.com/hc/en-us/#contact)? If you do, would you DM us the ticket number you receive?
We’d like to take a deeper look.
I have tried to submit a video, but had to send a link. Then I got an auto-response.
Hi @Ala ,
We’ve found the ticket. Our developers are taking a look at your video.
