Guide Issues again
4th gen tablo, ONN Google TV box. When I remove channels on the Your Channels page (after a rescan OR otherwise) and then hit Save and Continue, it does not remove the deselected channels. No matter how many times I try, it simply won’t work. I’ve tried updating the guide, closing out and returning, clearing cache, using my mobile settings, etc. PLEASE help…it’s beyond frustrating.
It’s been doing the same here. Two channels I watched changed to infomercials. I deselected the channels and it won’t save. I would submit another ticket, but I have several open right now for guide data, missing channels that show in the channel scan, but not in the guide, and wrong channel guide data.
I simply cannot get it to cooperate. I also have missing programming data from part of my guide, and I’m getting constant errors on my ABC channel(s) when trying to set up recordings. First things first…I’d like to get my guide set up with the channels I want. I’ve encountered this many, many times over the years but never this persistently.
After this length of time without the problem being addressed, I’m assuming this is something that can’t be fixed. Unbelievable.
What I find that sometimes works is to uncheck the channels that I don’t want then do a rescan and save.
Most of the time the check marks go away in Your Channels. After it updates itself.
If you have channels in the Live Guide after uncheck and save… You have to wait for a second update to finish. Even then they don’t always go away.
After the second automatic update finishes I exit the app then re-execute to see if it’s gone. If not it will often go away overnight during scheduled maintenance.
It’s very unpredictable.
I’ve gotten through all the prior steps and stared at Live Guide with the channel displayed. Then it vanished before my eyes.
